ISE onboarding - Max device
wileong
Understand that the max device limit is a deployment wide setting. I'm in a POV right now and customer would like to have the limit based on different group of user.
I have explored Max session but this only apply for internal group and we will have to set the limit based on external AD group.
Do we have any workaround or is max device by different group feature is in the roadmap.
Wing Churn
hariholla
The Group based, Max Sessions restrictions are typically for guest users, hence its limited to internal user groups. If this is a critical ask for your customer then please reach out to the PM community (internally) for feature enhancement.
thanks,
~Hari
hariholla
thanks,
~Hari
