ISE Profilling problem
Roger Base
Level 4
Level 4
Hi.
I have activated my ISE to automatic profile my endpoints. My Cisco IP phones and accesspoints works well. But for some reason my Windows PC are also profilled as CiscoDevice. I could shift it manually to the correct group. But I will let the ISE node to do it automatically.  What should I do to correct this problem?
Venkatesh Attuluri
what are the probes that you are using for profiling
