12-18-2018 11:16 PM
Can ISE SXP propagate IP-SGT obtained directly from ISE RADIUS sessions (eg. wired, wireless and VPN AAA)? Assuming yes as there is an option in the ISE SXP settings however there isn't any further info in ISE 2.4 config guide and doesnt seem to work in my ISE 2.4p5 lab testing so far...
Thanks in advance,
Denis
Solved! Go to Solution.
12-19-2018 05:36 AM
For it to work, ISE needs at least one SXP peer. If you have no real one, you may put a dummy entry.
See also resources at Cisco TrustSec and Segmentation
12-19-2018 05:36 AM
