ISE test plan for Radius/TACACS device administration
ikoch
Hi all,
I just found this ISE POC test template:
ISE Proof of Concept (PoC) Test Plan Template
Does anybody have an up-to-date ISE test plan for Radius and TACACS device administration from a customer POC ?
Many thanks for your help,
Ingo
kthiruve
What specifically are looking for? Is it device administration for Radius?
I understand device administration for TACACS+.
I have a high level design questionairre that you can use to gather requirement.
http://cs.co/acstoise
Also I would like to know if it is PoC or POV.
Once you understand the requirement you can come up with what you need for a PoV.
Reason is that typically for device admin, you need a endclient(putty or other client supporting telnet/ssh)
Network devices, and ISE server. You also need external ID store and have a knowledge on what it is before doing PoC.
For a simple PoC to show TACACS+ functionality, you can use dcloud: ISE mobility sandbox v1.
Let me know.
Krishnan
Currently recommendation is to use dCloud ise mobility deep dive, this has a guide with ISE configuration
I am working on getting the mobility sandbox updated with full configuration
Hi Krishnan,
it is a POV onsite at my customer with AD integration into ISE.
We will be testing device authentication using Radius and also TACACS+.
Thank you,
Ingo
