ISE to AD join problem
kamal kumar
Level 2
Level 2
HI Team ,
I am getting below error while AD to ISE join . can someone help to point out what could be reason .
Error Description: Failed to find domain controller, please check network connectivity
Support Details...
Error Name: LW_ERROR_FAILED_FIND_DC
Error Code: 40049
Detailed Log:
Error Description :
Failed to find domain controller in domain 10.101.X.X : There are no available DC`s
Error Resolution :
Please make sure that one of the DC`s is reachable and it`s not configured as RODC. For further information please refer to the AD diagnostic tools
Join steps :
09:52:56 Joining to domain 10.101..X.X using user isexxxx
09:52:56   Searching for DC in domain 10.101..X.X
09:52:56 Failed to find domain controller in domain 10.101..X.X : There are no available DC`s
Marvin Rhoads
Your domain name is a subnet address? Unless it is, you need to provide the actual domain name which resolves in the configured DNS server.
Hi Marvin,
Thanks a lot . It is the IP address of the domain , our DNS was not resolving the name correctly . Now its working fine . Appreciate your help .
oatroshc
You use wrong domain name here. It could not be as IP address.
