ISE-to-ISE SXP: same HA design than pxGrid?
clandrai
Hello all,
Looking at using SXP to propagate IP-SGT mapping form one ISE cluster to another, and looking at the HA side of it, I was thinking at using the same approach as used with pxGrid, i.e. two dedicated nodes as SXP speaker on on cluster, two dedicated SXP lister on the other side - counting on the fact that mappings are replicated within the cluster, and under assumption that dedicated nodes are an option (resource-wise).
Would you recommend such an approach, can pxGrid design be transposed?
What would you recommend if we have to enable SXP on existing node (non-dedicated)?
Thanks and regards,
Christophe
jeppich
Hey Christophe,
Please email me directly, i need more details, let's discuss over a webex.
John
jeppich@cisco.com
jeppich
Hey Christophe,
John
jeppich@cisco.com
