ISE using 2 domains with trust established
Tim Lewis
I need to authenticate wireless network users from two different domains
abc.company.com
cde.company.com
There is trust between domains and ISE joined abc.company.com and it can authenticate and authorize users without issues.
Users from cde.company.com cannot be authenticated (I don't even get to authorization part).
My identity source list has only External ID listed and when I see what is the reason of failure, message states that Authentication has failed (not authorization) because user cannot be found in any identity listed.
Now, users from abc and cde companies are logging with their usernames only. Should they try to login with cde.company\username or something?
Has anyone done this before?
Thanks.
Tarik Admani
Hi you may want to check the ad logs after seeing them to trace mode. Also check the trust type and make sure it is set to external.
Sent from Cisco Technical Support Android App
6 Replies 6
Eduardo Aliaga
Level 4
Level 4
If you have trust between "abc.cde.company.com" and "cde.company.com" then it has to work without issues.
If you have single-sign-on then the machine will autocomplete the domain name even if you only specify the user.
If you don't have single-sign-on, then you have to scecify the domain name. For example cde\username or username@cdp.company.com
You can verify that trust is working by going to "Administration > Identity management > external identity source > active directory > attributes > add > select attributes from directory" There you can type cde\username and if you get the attributes that means you have a trust relationship between cde and abc.
Please rate if this helps
Jatin Katyal
If you were able to search the user attributes in the above test and confirm that trust has been established. After that you may have to add a UPN suffix or NETBIOS prefix to the username when authenticating to a domain that the ISE is not joined to (Trusted domain), including the child domains.
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
I have trust. I can get the user information with cde\user and  user@cde.company.com, but authentication is still not working. So, I see  the user, but it is still not being authenticated by the policy.
Here is log:
11001  Received RADIUS Access-Request
11017  RADIUS created a new session
Evaluating Service Selection Policy
15048  Queried PIP
15048  Queried PIP
15004  Matched rule
11507  Extracted EAP-Response/Identity
12300  Prepared EAP-Request proposing PEAP with challenge
11006  Returned RADIUS Access-Challenge
11018  RADIUS is re-using an existing session
12302  Extracted EAP-Response containing PEAP challenge-response and accepting PEAP as negotiated
12318  Successfully negotiated PEAP version 0
12800  Extracted first TLS record; TLS handshake started
12805  Extracted TLS ClientHello message
12806  Prepared TLS ServerHello message
12807  Prepared TLS Certificate message
12810  Prepared TLS ServerDone message
12305  Prepared EAP-Request with another PEAP challenge
12304  Extracted EAP-Response containing PEAP challenge-response
12812  Extracted TLS ClientKeyExchange message
12804  Extracted TLS Finished message
12801  Prepared TLS ChangeCipherSpec message
12802  Prepared TLS Finished message
12816  TLS handshake succeeded
12509  EAP-TLS full handshake finished successfully
12313  PEAP inner method started
11521  Prepared EAP-Request/Identity for inner EAP method
11522  Extracted EAP-Response/Identity for inner EAP method
11806  Prepared EAP-Request for inner method proposing EAP-MSCHAP with challenge
11808  Extracted EAP-Response containing EAP-MSCHAP challenge-response for inner method and accepting EAP-MSCHAP as negotiated
Evaluating Identity Policy
15006  Matched Default Rule
15013  Selected Identity Store - AD-Suffolk
24430  Authenticating user against Active Directory
24412  User not found in Active Directory
22056  Subject not found in the applicable identity store(s)
22058  The advanced option that is configured for an unknown user is used
22062  The 'Drop' advanced option is configured in case of a failed authentication request
12315  PEAP inner method finished with failure
22028  Authentication failed and the advanced options are ignored
Looking at the above message, it seems the authentication request got stuck at the identity store as user not found there. Is DNS resolution working fine for your trusted domain from the ISE. Could you please login to ISE CLI and issue:
nslookup trusted-domain
In case it works fine then you may need to fetch the debug level ISE-AD communication from ACS.
btw, what version of ISE are you running?
~BR
Jatin Katyal
~Jatin
Ravi Singh
Level 7
Level 7
If there is trust between domain and it should work fine. As you are stuck user not found error you have to cross check that you are able to reach the AD from ISE or not. Perform network trace and also check DNS resolution.
Tarik Admani
