ISE with WLC AND switches
Sheraz.Salim
we are running 3xWLC controller with 800 AP using ISE 1.2 for wireless authentication 802.1x. I was looking into the config for the ISE and notice out of 400 edge swtiches only 2x2960s are configured with 802.1x (ISE config Radius and SNMP) and only 2 of the port there is 2 ap attach with swtich ports.and remaing the 3XWLC in Network Devices.
i do not understand how one ap is doing this job (802.1x) as it is location on different location and people are connecting to various different locations. ISE almost running/doing 11,876 Profiled endpoints.
version 12.2
boot-start-marker
boot-end-marker
enable secret 5 $1$fokm$lesIWAaceFFs.SpNdJi7t.
username test-radius password 7 07233544471A1C5445415F
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa authorization auth-proxy default group radius
aaa accounting dot1x default start-stop group radius
aaa accounting system default start-stop group radius
aaa server radius dynamic-author
 client 10.178.5.152 server-key 7 151E1F040D392E
 client 10.178.5.153 server-key 7 060A1B29455D0C
aaa session-id common
switch 1 provision ws-c2960s-48fps-l
authentication critical recovery delay 1000
ip dhcp snooping vlan 29,320,401
no ip dhcp snooping information option
ip dhcp snooping
no ip domain-lookup
ip device tracking
epm logging
crypto pki trustpoint TP-self-signed-364377856
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-364377856
 revocation-check none
 rsakeypair TP-self-signed-364377856
crypto pki certificate chain TP-self-signed-364377856
 certificate self-signed 01
  30820247 308201B0 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33363433 37373835 36301E17 0D393330 33303130 30303331
  305A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3336 34333737
  38353630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  B09F8205 9DD44616 858B1F49 A27F94E4 9E9C3504 F56E18EB 6D1A1309 15C20A3D
  31FCE168 5A8C610B 7F77E7FC D9AD3856 E4BABDD1 DFB28F54 6C24229D 97756ED4
  975E2222 939CF878 48D7F894 618279CF 2F9C4AD5 4008AFBB 19733DDB 92BDF73E
  B43E0071 C7DC51C6 B9A43C6A FF035C63 B53E26E2 C0522D40 3F850F0B 734DADED
  02030100 01A37130 6F300F06 03551D13 0101FF04 05300301 01FF301C 0603551D
  11041530 13821150 5F494D2B 545F5374 61636B5F 322D312E 301F0603 551D2304
  18301680 1456F3D9 23759254 57BA0966 7C6C3A71 FFF07CE0 A2301D06 03551D0E
  04160414 56F3D923 75925457 BA09667C 6C3A71FF F07CE0A2 300D0609 2A864886
  F70D0101 04050003 81810062 819657B5 5B1CA52E B38AC231 12764661 E45F3AF6
  F08D258E EAA2762F F90FBB7F F6E3AA8C 3EE98DB0 842E82E2 F88E60E0 80C1CF27
  DE9D9AC7 04649AEA 51C49BD7 7BCE9C5A 67093FB5 09495971 926542C4 5A7C7022
  8D9A8C2B 794D99B2 3B92B936 526216E0 79D80425 12B33847 30F9A3F6 9CAC4D3C
  7C96AA15 CC4CC1C0 5FAD3B
        quit
dot1x system-auth-control
dot1x critical eapol
spanning-tree mode pvst
no spanning-tree vlan 294-312,314-319,321-335,337-345,400,480,484-493,499,950
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
errdisable recovery cause psp
vlan internal allocation policy ascending
interface GigabitEthernet1/0/10
 switchport access vlan 320
 switchport mode access
 ip access-group ACL-ALLOW in
 authentication event fail action next-method
 authentication event server dead action authorize
 authentication event server alive action reinitialize
 authentication host-mode multi-domain
 authentication open
 authentication order dot1x mab
 authentication priority dot1x mab
 authentication port-control auto
 authentication periodic
 authentication violation replace
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 10
 spanning-tree portfast
 spanning-tree bpduguard enable
interface GigabitEthernet1/0/16
 authentication open
 mab
interface GigabitEthernet1/0/24
 authentication open
 mab
interface GigabitEthernet1/0/33
 authentication open
 mab
interface GigabitEthernet1/0/34
 authentication open
 mab
interface GigabitEthernet1/0/44
 authentication open
 mab
interface GigabitEthernet1/0/46
 authentication open
 mab
interface GigabitEthernet1/0/48
 authentication open
 mab
interface GigabitEthernet1/0/49
 description Link-to-GH
 switchport trunk allowed vlan 1,2,320,350,351,401
 switchport mode trunk
 mls qos trust dscp
 ip dhcp snooping trust
interface GigabitEthernet1/0/52
 description Link-to-CORE1
 switchport trunk allowed vlan 1,2,29,277,278,314,320,401
 mls qos trust dscp
interface Vlan320
 ip address 10.178.61.5 255.255.255.128
 no ip route-cache cef
 no ip route-cache
ip default-gateway 10.178.61.1
ip http server
ip http secure-server
ip http secure-active-session-modules none
ip http active-session-modules none
ip access-list extended ACL-AGENT-REDIRECT
 deny   udp any any eq domain bootps
 permit tcp any any eq www
 permit tcp any any eq 443
ip access-list extended ACL-ALLOW
 permit ip any any
ip access-list extended ACL-DEFAULT
 permit udp any eq bootpc any eq bootps
 permit udp any any eq domain
 permit icmp any any
 permit tcp any host 10.178.5.152 eq 8443
 permit tcp any host 10.178.5.152 eq 8905
 permit udp any host 10.178.5.152 eq 8905
 permit tcp any host 10.178.5.152 eq 8906
 permit udp any host 10.178.5.152 eq 8906
 permit tcp any host 10.178.5.152 eq 8909
 permit udp any host 10.178.5.152 eq 8909
 permit tcp any host 10.178.5.153 eq 8443
 permit tcp any host 10.178.5.153 eq 8905
 permit udp any host 10.178.5.153 eq 8905
 permit tcp any host 10.178.5.153 eq 8906
 permit udp any host 10.178.5.153 eq 8906
 permit tcp any host 10.178.5.153 eq 8909
 permit udp any host 10.178.5.153 eq 8909
 deny   ip any any
ip access-list extended ACL-WEBAUTH-REDIRECT
 deny   ip any host 10.178.5.152
 deny   ip any host 10.178.5.153
ip radius source-interface Vlan320
logging esm config
logging trap alerts
logging origin-id ip
logging source-interface Vlan320
logging 192.168.6.31
logging host 10.178.5.150 transport udp port 20514
logging host 10.178.5.151 transport udp port 20514
access-list 10 permit 10.178.5.117
access-list 10 permit 10.178.61.100
snmp-server engineID local 800000090300000A8AF5F181
snmp-server community W143L355 RO
snmp-server community w143l355 RW
snmp-server community lthpublic RO
snmp-server community lthise RO
snmp-server trap-source Vlan320
snmp-server source-interface informs Vlan320
snmp-server enable traps snmp authentication linkdown linkup coldstart
snmp-server enable traps cluster
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host 10.178.5.152 version 2c lthise  mac-notification
snmp-server host 10.178.5.153 version 2c lthise  mac-notification
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 5 tries 3
radius-server host 10.178.5.152 auth-port 1812 acct-port 1813 test username test-radius key 7 03084F030F1C24
radius-server host 10.178.5.153 auth-port 1812 acct-port 1813 test username test-radius key 7 141B060305172F
radius-server vsa send accounting
radius-server vsa send authentication
any hlep would be really appriciated.
please do not forget to rate.
Marvin Rhoads
I'm not sure I completely understand the question; but if ISE is only doing wireless policies, then none of the wired switches need any ISE configuration.
The APs tunnel all the wireless traffic back to the WLC over CAPWAP (unless you're using FlexConnect). It's the 802.1x configuration on the WLC that implements the policies defined in ISE.
The wired switches never need to act as a Network Access Device (NAD) and thus do not need to be defined in ISE unless or until you want to implement ISE policies for wired devices..
6 Replies 6
Marvin Rhoads
Hi Marvin.
Thank you very much for your responce. we are not using FlexConnect on AP.
I am curious to understand is it possible only one ap out of 800 ap is doing only 802.1x authentication of all the endclient in different locations? is it possible or i am missing something else here.
your answer would be highly appriciated.
Thanks in advacne.
You're welcome.
The 802.1x authentication is not done by the AP(s)  - they only pass it back to the WLC where it is done (or not) according to the authenticaiton configuration settings for the SSIDs.
All APs (or AP groups) that have those SSIDs associated with them should be passing the traffic back for the WLC to handle 802.1x authentication in conjunction with your ISE deployment.
Thank Marvin.
just last question to clearfiy myself. I do agree WLC do the authentiaction on SSID. where we define the Radius server ip address.
I do understand what you said. but can one AP do this. as I see this in my organization only one AP is configured with this swtich (In ISE Devices Group).
so my undestanding is one AP is configured with these settings
 authentication open
 mab
is it right. but you mention WLC do all the authencation than there is no need for these above setting on this interface where the ap is connected to this port.
if wlc do all the authenction then the above setting dont need to be on the AP interface right?
i am sorry if i am asking too many question.
I do really appricate for your input.
Those settings are not needed for the wireless clients.
You may choose to still authenticate the AP itself as a device. I suspect if you check the authentication status of that interface, it is using MAB for the AP.
show authentication sessions interface gi1/0/34 detail
...will tell us.
Thank you very much.
