ISE with Zabbix (system summary dashboard info of ISE)
musultan
I am looking for the integration of ISE with Zabbix (an open source - enterprise-level software designed for real-time monitoring)
We are looking for the following information (i-e., the system summary dashboard of ISE) to be displayed in Zabbix system.
1. CPU
2. Memory
3. Auth latency
4. Node status (active or down)
5. Replication status. (completed or not)
I don’t think this info can be obtained via the REST API and incomplete with SNMP (only CPU and Memory info can be obtained via SNMP)
Also, We are looking to have these values more customizable other than only to receive info hourly/24 or minutely/60.
I’m wondering basically if there is an easier way to get these values as it can’t seem to be done completely with SNMP or at all with REST API.
Timothy Abbott
Hi Mubasher,
Another option you could look at would be syslog. ISE has System Diagnostics and Statics that it collects and can be sent via syslog to a remotely configured target.
-Tim
musultan
I am still looking for information. Any update please?
Timothy Abbott
Hi Mubasher,
-Tim
