Issue with authentication with RADIUS when using VPN
jaroslavremen4
Frequent Visitor
Frequent Visitor
Our customer has a problem with auhtentication against Radius vhen he is using VPN or SSL VPN. Authentication on SSH or TELNET via RADIUS is working fine . When I configure on VPN (and SSL VPN) authentication against the local database, everything is working fine and tunnel is established.
In attachement is running-config of customer's gateway and capture file of communication between RADIUS server and gateway (radius access request starting at 85th line).
I found in this file at AVP attributes that the gateway is sending ipsec profile name (in this case "VPN") instead of username.
jvanhouten
Community Member
SSLVPN is configured to use the local database of usernames only in this config. It is not configured to use RADIUS.
