Issue with Device Admin Policy Sets Not Loading in ISE 3.0 on VM
Hello team ,
I have set up a virtual machine using the ISE 3.0 OVA image and am currently using the evaluation license. The problem I’m facing is that when I navigate to the "Device Admin Policy Sets" page, it does not load.
Here’s what I’ve done so far:
  • I’ve ensured that Device Administration is enabled in the Deployment section.
  • When checking the licensing, I can see that the Device Admin license consumption is set to 1, meaning it’s active.
  • Other sections of ISE are functioning as expected.
  • I’ve even tried re-uploading the OVA image, but the issue persists.
What could be causing this? Could there be a configuration I’m overlooking, or could it be related to a compatibility issue or bug with the OVA image?
Any insights or troubleshooting tips would be greatly appreciated!
Thank you
Arne Bier
ISE 3.0 is so long ago for me, I can't remember if I ever encountered that.  Have you applied the latest ISE 3.0 patch to that node?  I would try that. In eval mode you should have no limitations on TACACS+, and you have performed all the right checks already.
I also assume that you are the super admin user with Read/Write RBAC for all menus and data ?
hello ,
thank you , after applying the patch 8 , the issus is resolved
