Issues using ISE
Hello everybody,
I just installed ISE 2.7 on a virtual machine but I can't seem to be able to use it, since everytime I try to configure anything from UI, I get this kind of errors:
idMgmtUserAction.do?command=list status:0
Unable to load NetworkDevicesLPInputAction.do?command=container status:0
Unable to load DefaultNetworkDeviceInputAction.do?command=enterPage status:0
any idea to solve this?
I just forgot I had my VPN on, that was the issue. Thank you, everyone!
Mike.Cifelli
I would suggest three things:
1- make sure you have the proper resources allocated for the vm
2- try applying a patch (perhaps 2.7p4) to see if that fixes the problem
3- try another browser (if you have not already done so)
