local username does not work when management interface is down
dwsmithjr
On switches when the management interface is down (vlan1), we cannot login from the console using the local username and password. if the management interface is up but TACACS is not available, it works fine for a vty interface. If you connect to console and TACACS is available, the TACACS login for course works and local does not.
We need to be able to use the command "username xxx secret" and be able to login when connected to the console port when TACACS is not available or the management interface is down, using the local username and password.
7 Replies 7
Can you please post the AAA configuration on your switch?
Javier Henderson
Cisco Systems
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting update newinfo
username XXX secret XXXXXX
We will need more to go further, for example, do you have VLAN 1 as the source for TACACS+ packets?
When I said the AAA configuration, I meant everything related to it.
Javier Henderson
Cisco Systems
Yes, Vlan1 is the TACACS source interface. I'll gather the rest of the configuration information relating to TACACS. We are able to login with the local account when we connect remotely using a vty interface (SSH) and TACACS is not available. That works fine.
We cannot login using the console interface when the router is disconnected from the network, say when it is being initially configured, has been rebooted and the tech is trying to reconnect through the console port. So, the management interface or vlan is down.
Here is the scenario. A tech is configuring a switch to be deployed to a location using the console port. They add the configuration which includes "username XXX secret XXXXXXX. They then save the configuration and reboot the switch. The switch is not connected to any network at this point.
When the switch comes up, they attempt to login again through the console port and cannot authenticate. The login is denied.
Vlan1 is the management interface and the TACACS source interface.
Let me know if you need anything else.
aaa group server tacacs+ ACS53
 server name XXX
 server name XXX
aaa session-id common
interface Vlan1
 description <Serial number and Asset tag>
 ip address <INSERT SWITCH IP ADDRESS> xxx.xxx.xxx.0
 no ip redirects
 no ip unreachables
 no ip route-cache
 no shut
 ip tacacs source-interface Vlan1
tacacs-server timeout 20
tacacs server XXX
 address ipv4 xx.xxx.xxx.xxx
 key 7 xxxxxxxxxxxxxxxx
tacacs server XXX
 address ipv4 xxx.xxx.xxx.xxx
tacacs-server directed-request
We've resolved the issue. It was a "user error" on the part of some of the people configuring the switches.
