Max number of Network devices for TACACS+ in ISE
yongwli
Hi Team,
As we know, max number of network devices is 100K.
Two questions:
1. This number is a number based on performance experienced or it's a limitation in ISE software?
2. If defining 1 network device with IP range, IE /24 subnet, it exhausts 1 entry or 254 entries?
DL
To clarify, a subnet range does not consume or equate to one NAD per IP.  Only NADs that connect to ISE will have a cache entry.  100k is what we have validated in QA testing.  This is not a hard limit, but certainly would not plan on exceeding.  If know deployment will exceed, then recommend design for split clusters.  Also recommend reach out to account team to submit requirements for higher scale so we know which customers actually require > 100k NADs.
/Craig
6 Replies 6
Charlie Moreton
     - Database Limitation
     - This counts as a single 'Device'
Thanks a lot!
/Craig
Hi Craig,
we have asked customer to do cluster split, does single PSN have a recommend number of network device? Then we could know how to split.
DL
Sizing is based on transaction rate, not # NADs.
Hi DL,
ISE supports upto 100 K Network device entries per deployment. This includes PAN, MnT and x number of PSN’s.
Question is if you want to calculate number of PSN’s this is based on TACACS+ TPS.
If the customer has ACS and is not oversubscribed you can easily replace an authenticating ACS server with an ISE PSN.
For more information on designing ISE deployment please see the how to guide that I just updated yesterday. It will walk you step by step how to design ISE deployment for TACACS+ with tables etc.
https://communities.cisco.com/docs/DOC-63880
You can also look at Craig’s breakout session on Scaling in 2016
https://communities.cisco.com/docs/DOC-63882
Krishnan
