Max Sessions on ACS 3.3
tmoore
Trying to setup max session to limit the number of concurrent connection a user can have to a AAA device. The user Max session is set to 3 but does not seem to have any affect. Accounting logging is using TACACS+ Accounting reports with start and stop attributes logged. I see the logged in user number increase for the AAA devices. The send Accounting Information for the AAA Server is set to Local, would this be causing the max session feature not to work.
darpotter
Level 5
Level 5
I know this used to work in 3.1... could be that its been broken.
If you are seeing accounting start/stops in the T+ accounting log it should be ok.
The local setting for acs accounting is fine.. thats more to do with if you had authententication proxy you can control who also gets the accounting.
