Maximum storage for ACS logging vs ISE
Tze Tai Mak
Dear all,
My customer is migrating from ACS to ISE.
Their existing ACS HW SNS-3515 only support a max. of 750GB HD which is not enough for them.
If they migrate to ISE, how to compare the ACS logging vs ISE device admin logging?
For each TACACS+ event, is it around the same logging size taken? what is the max logging size for TACACS+ events?
Thanks, Tommy
Craig Hyps
Level 10
Level 10
This is the ISE support community, so I will answer the questions specific to ISE.
SNS-3515 has 600GB drive space (not 750GB), of which 60% is allocated to RADIUS and T+ logging in ISE 2.2+ with an additional 20% overhead for purging.  Effective storage and guidance on days retention are included in ISE Install Guide.
For additional info, see
ISE Device Administration (TACACS+)
ACS to ISE Migration
Also see Reference version of presentation for BRKSEC-3699 from this year on ciscolive.com.  It contains information on general packet sizes and counts for different T+ operations.
Craig
Craig Hyps
Level 10
Level 10
Craig
