Monitoring and Reporting on ACS 5.1 not working
sshantikumar
I have not managed to get the Monitoring to work on the ACS 5.1. This is an eval version. Advanced monitoring and reporting is installed on the ACS. This is my configuration on the Cisco Router
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
logging origin-id ip
logging facility syslog
logging source-interface GigabitEthernet1/1
logging host 1.1.1.1 transport udp port 20514
logging monitor informational
epm logging
On the ACS, when I open the dashboard --> ACS health  -> I get Status not available.
Global Instance under Logging Categories been configured for local logging
sshantikumar
The view logprocessor is not running
ACS role: PRIMARY
Process 'database'                  running
Process 'management'                running
Process 'runtime'                   running
Process 'adclient'                  running
Process 'view-database'             running
Process 'view-jobmanager'           running
Process 'view-alertmanager'         running
Process 'view-collector'            running
Process 'view-logprocessor'         not monitored
Does anyone know how to start it??
Looks like there is a known bug for this.
CSCte95063
After "clock set" view log processor goes to 'not monitored' state.
Can anyone confirm that if i install the patch 5-1-0-44-4.tar.gpg, this issue will be resolved
It works by removing the clock set command and restarting ACS. It now works fine
TM13
Is it affects v5.2.0.26? because we having this problem but want to confirm before restarting production equipment ....?!
