NAC Agent Problem
arifsbaqi9
Community Member
recently i am facing a probelm with NAC agent , it does not check for the updates when the user is login , there is a massege come ( please check the attchments ) .
please help me !!!
6 Replies 6
Tarik Admani
Arif,
Are you running nac agent version 4.8.1.5 and is this device mac address whitelisted in the filters list?
Tarik
I am useing NAC agent version 4.7.4.2 , yes it is listed in filters list , when i remove it , it's work .
but how to upgarad it to 4.8.1.5 .
What version is your clean access deployment? Also with the client in the filtered list which device filter type are you enforcing on this client?
Tarik
the clean access version 4.7.2.507 & the NAC is checking the AV definition & WSUS windows update .
Recently , when the user is loging off & loging on , the NAC agent proceed for checking again & again , this problem is
strain the user of every time his faceing this check & time waste .
what i know the NAC is proceed for check if the user is rebooting the machine , but for login & logoff !!!!!!!!.
there is any solution to prevent this issue .
Also , some of computers the NAC agent comes frequently the user cannot login to the network , it is searching without stop .
