Need ACS Help
s-beavers
I need to update an ACS Server from v2.6 to v3.0. I need to replicate to another server. Are there any gotcha or issues?
Thanx.
wong34539
Level 11
Level 11
The following document has the required procedures and issues you have to check for,
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt30/install/install.htm
