Need help - ACS 4.2
Anukalp S
Hi All,
I want give access or authentication to a specifc user on only two devices in ACS4.2. i am facing challenge while doing this using NAR. Can anyone pls help me out and show the exact process to do this, that would be apprecialble.
2 Accepted Solutions
Jatin Katyal
You can use ip based NAR for the specific user.
Go to user setup > edit user > Advanced settings > Network access restriction.
Check: Define IP-based access restrictions.
Permitted calling/point of access location .
Select the AAA clients you want to permit access.
For port and address use (*) without quotes.
Click enter.
Jatin Katyal
- Do rate helpful posts -
Advanced Settings
Network Access Restrictions (NAR) Help on Network Access Restrictions (NAR)
  Per User Defined Network Access  Restrictions
~Jatin
Thanks a lot Jatin, its working.
Jatin Katyal
Click enter.
Jatin Katyal
Advanced Settings
~Jatin
Glad to know
~Jatin
