04-19-2013 03:26 AM - edited 03-10-2019 08:20 PM
Hi All,
I want give access or authentication to a specifc user on only two devices in ACS4.2. i am facing challenge while doing this using NAR. Can anyone pls help me out and show the exact process to do this, that would be apprecialble.
Solved! Go to Solution.
04-19-2013 05:44 AM
You can use ip based NAR for the specific user.
Go to user setup > edit user > Advanced settings > Network access restriction.
Check: Define IP-based access restrictions.
Permitted calling/point of access location .
Select the AAA clients you want to permit access.
For port and address use (*) without quotes.
Click enter.
Jatin Katyal
- Do rate helpful posts -
04-19-2013 09:46 AM
Thanks a lot Jatin, its working.
04-19-2013 05:44 AM
Click enter.
Jatin Katyal
04-19-2013 09:46 AM
04-19-2013 09:56 AM
Glad to know
