Need Help - Cisco ISE 2.3 & Meraki MR42 BYOD
vijaydabasia
Hi All,
I have Meraki MR42 configured for BYOD SSID which points to our Cisco ISE server. Connection from Meraki to ISE works as i've already tested 802.1x authentication with LDAP for laptops on WiFi.
I have followed various configuration guide to setup BYOD for employees and struggling to get it working I can't use the wizard as i'm not using WLC. I have got to a stage where i'm getting "15052 Authorization profile/s specified are not suited for this Network Access Device" if tried Andriod and iPhone with the same result.
See attached RADIUS Log - PDF
Authentication Policy:
What am I missing?
VJ
Timothy Abbott
You have a BYOD SGT applied.  Meraki does not support TrustSec currently.  Try removing the SGT.
-Tim
Hi Tim,
I have removed the SG from the Authentication policy but still get the same result.
Jason Kunst
Make sure under your NAD profile you’re using Cisco as it’s treated the same as cisco wlc
