Need help with aaa configuration on cisco WS-C3548-XL using Radius authentication
SACHIN SHARMA
Hi All ,
we are configuring all our network switches with Radius authentication ,we are able to roll out on most of the switches successfully ,but the cisco WS-C3548-XL (C3500XL-C3H2S-M) switch with IOS Version 12.0(5)WC8, RELEASE SOFTWARE (fc1)  is not accepting our default configuration commands as below
aaa new-model
aaa authentication login default group radius local
ip radius source-interface VlanXX ( Specify Management Vlan)
radius-server host XX.XX.XX.XX auth-port 1645 acct-port 1646 key *******
radius-server source-ports 1645-1646 aaa new-model
Any help regarding this is appreciated.
edwjames
Level 3
Level 3
Hi Kalyan,
What is the error message that you receive?
See if this helps:
https://supportforums.cisco.com/thread/218313
**Share your knowledge. It’s a way to achieve immortality.
--Dalai Lama**
Please Rate if helpful.
Ed
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
10 Replies 10
edwjames
Level 3
Level 3
Hi Kalyan,
See if this helps:
--Dalai Lama**
Ed
I do not know if this is just an artifact of cut and paste for this message or whether it is really what you are using, but this line would certainly be rejected for invalid syntax if you did input it to a switch
If it is just a cut and paste issue then I agree with Ed that we need more information about what part is not accepted and any messages that are generated. I would also appreciate some clarification about whether you are experiencing this problem on a single particular switch or whether you are experiencing it on several switches all of which are WS-C3548-XL (C3500XL-C3H2S-M)
Rick
Rick
Hi Rick,
that was a typo and yes it is happening on all similar switch models.
Hi Ed ,
it wont give any error i see it does not recognize the command format
Switch(config)#aaa new-model
Switch(config)#aaa authentication login default group radius local
Switch(config)#$auth-port 1645 acct-port 1646 key ******
% Invalid input detected at '^' marker.
Switch(config)#
Kalyan,
What do you get for :
"radius?"
try to use "?" to fill the command.
the syntax might be different on this guy.
--Dalai Lama**
Ed
Ed,
Here you go
Switch(config)#radius ?
% Unrecognized command
Switch(config)#
i just want to know which is the syntax equivalent of the below
radius-server host 172.26.0.11 auth-port 1645 acct-port 1646 key *****
What do you get if you try this
Switch(config)# ?
Rick
Rick
please see below
Switch(config)#?
Configure commands:
  aaa                         Authentication, Authorization and Accounting.
  access-list                 Add an access list entry
  alias                       Create command alias
  arp                         Set a static ARP entry
  banner                      Define a login banner
  boot                        Boot Commands
  buffers                     Adjust system buffer pool parameters
  cdp                         Global CDP configuration subcommands
  cgmp                        Global CGMP configuration commands
  class-map                   Configure QoS Class Map
  clock                       Configure time-of-day clock
  cluster                     Cluster configuration commands
  default                     Set a command to its defaults
  default-value               Default character-bits values
  downward-compatible-config  Generate a configuration compatible with older
                              software
  enable                      Modify enable password parameters
  end                         Exit from configure mode
  exception                   Exception handling
  exit                        Exit from configure mode
  file                        Adjust file system parameters
  help                        Description of the interactive help system
  hostname                    Set system's network name
  interface                   Select an interface to configure
  ip                          Global IP configuration subcommands
  line                        Configure a terminal line
  logging                     Modify message logging facilities
  mac-address-table           Configure the MAC address table
  map-class                   Configure static map class
  map-list                    Configure static map list
  no                          Negate a command or set its defaults
  ntp                         Configure NTP
  policy-map                  Configure QoS Policy Map
  priority-list               Build a priority list
  privilege                   Command privilege parameters
  queue-list                  Build a custom queue list
  rmon                        Remote Monitoring
  scheduler                   Scheduler parameters
  service                     Modify use of network based services
  shutdown                    Shutdown system elements
  snmp-server                 Modify SNMP parameters
  spanning-tree               Spanning Tree Subsystem
  stackmaker                  Specify stack name and add its member
  tacacs-server               Modify TACACS query parameters
  tftp-server                 Provide TFTP service for netload requests
  time-range                  Define time range entries
  udld                        Configure global UDLD setting
  username                    Establish User Name Authentication
  vmps                        VMPS settings
  vtp                         Configure global VTP state
Ed ,
See if this helps:
i tried this on one of the switch and it worked ,i am trying on the other switches.
Awesome, lemme know how it goes..
Good to know.
--Dalai Lama**
Ed
