Nexus 7009 using radius authentication
jtolbert23
Frequent Visitor
Frequent Visitor
I have setup my radius server access on the Nexus but am unable to authenticate through putty. If I do a radius-server test on the Nexus it says I authenticate. Here is the log I am getting. I would appreciate any help.
2012 Mar 14 16:03:21 switch-a %AUTHPRIV-4-SYSTEM_MSG: pam_unix(aaa:auth): check
pass; user unknown - aaad
2012 Mar 14 16:03:21 switch-a %AUTHPRIV-5-SYSTEM_MSG: pam_unix(aaa:auth): authen
tication failure; logname= uid=0 euid=0 tty= ruser= rhost=  - aaad
2012 Mar 14 16:03:23 switch-a %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication fai
led for user jeffrey6596 from 10.10.22.145 - sshd[13568]
2012 Mar 14 16:03:23 switch-a %AUTHPRIV-5-SYSTEM_MSG: Login failed for user jeff
rey6596 - sshd[13568]
2012 Mar 14 16:03:23 switch-a %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication f
ailure for illegal user jeffrey6596 from 10.10.22.145 - sshd[13561]
Eduardo Aliaga
Level 9
Level 9
Could you post the nexus config? What's the radius server ? could you post the logs of the radius server?
