Not Working-central web-authentication with a switch and Identity Service Engine
Nuno Moreira
on the followup the document "Configuration example : central web-authentication with a switch and Identity Service Engine" by Nicolas Darchis, since the redirection on the switch is not working, i'm asking for your help...
I'm using ISE Version : 1.0.4.573 and WS-C2960-24PC-L w/software 12.2(55)SE1 and image C2960-LANBASEK9-M for the access.
The interface configuration looks like this:
interface FastEthernet0/24
switchport access vlan 6
switchport mode access
switchport voice vlan 20
ip access-group webauth in
authentication event fail action next-method
authentication event server dead action authorize
authentication event server alive action reinitialize
authentication order mab
authentication priority mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation restrict
mab
spanning-tree portfast
end
The ACL's
Extended IP access list webauth
    10 permit ip any any
Extended IP access list redirect
    10 deny ip any host 172.22.2.38
    20 permit tcp any any eq www
    30 permit tcp any any eq 443
The ISE side configuration I follow it step by step...
When I conect the XP client, e see the following Autenthication session...
swlx0x0x#show authentication sessions interface fastEthernet 0/24
           Interface:  FastEthernet0/24
          MAC Address:  0015.c549.5c99
           IP Address:  172.22.3.184
            User-Name:  00-15-C5-49-5C-99
               Status:  Authz Success
               Domain:  DATA
       Oper host mode:  single-host
     Oper control dir:  both
        Authorized By:  Authentication Server
           Vlan Group:  N/A
     URL Redirect ACL:  redirect
         URL Redirect: https://ISE-ip:8443/guestportal/gateway?sessionId=AC16011F000000510B44FBD2&action=cwa
      Session timeout:  N/A
         Idle timeout:  N/A
    Common Session ID:  AC16011F000000490AC1A9E2
      Acct Session ID:  0x00000077
               Handle:  0xB7000049
Runnable methods list:
       Method   State
       mab      Authc Success
But there is no redirection, and I get the the following message on switch console:
756005: Mar 28 11:40:30: epm-redirect:IP=172.22.3.184: No redirection policy for this host
756006: Mar 28 11:40:30: epm-redirect:IDB=FastEthernet0/24: In epm_host_ingress_traffic_qualify ...
I have to mention I'm using an http proxy on port 8080...
Any Ideas on what is going wrong?
Nuno
15 Replies 15
I had the same issue and it turned out to be my captive portal acl. See below:
This ACL MUST be configured on the switch beforehand (some documentation eludes to using a downloadable ACL for this)
This ACL MUST contain DENY statements for traffic going to External Portal.
  • This prevents traffic getting redirected to portal from getting stuck in a redirect loop
This ACL MUST contain PERMIT statements for traffic that you want the switch to intercept and redirect to the external portal
Here is an working example for redirecting traffic to captive port (1.1.1.1 in this and following examples):
ip access-list extended captive_portal
 deny   tcp any host 1.1.1.1
 permit tcp any any
