Ping Cisco Secure ACS Solution Engine
aalsayed
Community Member
1- i installed Cisco Secure ACS Solution Engine wiht V3.3 and i can access through http port 2002 but i cant ping it from any where in network but the server can ping every thing ,, is this normal.
2- if i cant ping it haw i can define the service keeplaive to load balance 2 ACS engine using CSS
By the way, I forgot that ACS 3.3 appliance has a built-in CSA. This agent is enabled by default. It explains why you can't ping it.
To disable/enable it, go to "System Configuration - Appliance Configuration". Enable/disable the CSA Enabled check box as required.
http://www.cisco.com/en/US/partner/products/sw/secursw/ps5338/products_user_guide_chapter09186a008023361d.html#wp859228
Rgds,
AK
a.kiprawih
Level 11
Level 11
Once ACS is configured properly, you can always ping the server, just like other network host/device.
Check your ACS network configuration again. You shouldn't get timeout if your ACS is properly configured.
ACS Appliance 3.3:
http://www.cisco.com/en/US/partner/products/sw/secursw/ps5338/products_installation_guide_chapter09186a0080235f77.html#wp1065366
Doc for CSS Keepalive:
http://www.cisco.com/en/US/partner/products/hw/contnetw/ps789/products_tech_note09186a0080093ded.shtml
Rgds,
AK
Rgds,
AK
Dear Sir
thnx .. it is working now
