ppp radius problem
mehmetsonmez
Community Member
Hi guys my problem is about Radius.It can not assign ip to remote host.This host request ppp and it terminated by on our Cisco router(LAC-LNS).And Cisco router uses AAA for authentication and ip assignment.Authentication part is okey.The host can connect radius and passes username password phase.But when the ppp protocol pass next ipcp level, host request;confreq is above,
Primary DNS server IP address: 0.0.0.0
Secondary DNS server IP address: 0.0.0.0
Primary WINS server IP address: 0.0.0.0
Secondary WINS server IP address: 0.0.0.0
IP address: 0.0.0.0
But the Router returns reject;confrej
IP address: 0.0.0.0
After this negotiation ppp ipcp part is terminated and the host never get ip address.
My question, Although the ppp authentication seems okey, why the remote host does not get ip address.Shoul I focus radius config. or Router config. ?
Thanks.
mavespig
Level 8
Level 8
Can you paste the configuration of the virtual-template?
Enable also deb ppp nego and deb radius and collect the logs.
Cheers
Marco
Hi Marco,
interface Virtual-Template1
ip unnumbered GigabitEthernet0/0.12
no ip mroute-cache
no peer default ip address
ppp authentication pap
ppp ipcp predictive
I will paste here also debug files.
Best regards
