Prevent Mobile Phones from Joining Corp WIFI with AD Credentials
alfred
Good day,
How do I prevent corporate users from using their AD credentials on their BYOD devices joining the domain using Cisco ISE, there is a guest WIFI that they can use for free.  Would appreciate input here as I am new to Cisco ISE.
Arne Bier
If you require EAP-PEAP for endpoints other than the BYOD devices, then you will need to be a bit more strict during Authorization.
In practice, that means that if you have an ISE Wireless 802.1X Policy Set, you can add a condition for that during EAP-PEAP should use AD Authentication (if that's what you're using)
And for Authorization, Have a Rule that allows the endpoint if it's a member of Domain Computers.
Then check all remaining Authorization conditions and make sure that a user's creds will never pass authorization.
If you have some VIP employees, create an AD Group for them and make them a member of that group - then only those users can use their personal devices for BYOD.
EAP-PEAP is a quick and dirty way to get onto the network - but things start going wrong when employees change their password, and then forget to change it on the BYOD devices - often times this unintentional situation causes the AD user's account to be locked due to too many attempts. Be warned.
A couple of options:
  • (best and most secure way) Switch to EAP-TLS using certificates and don't use username/passwords at all.  Disable PEAP at the allowed protocol level.
  • Use computer authentication only (not user).  Device must auth using its machine account.
  • Use profiling to only allow certain device types.
Arne Bier
