Problem installing 5-1-0-44-6 patch
camiloamedinar
I have a problem with the instalation 5.1.0.44.6 patch in ACS 5.1
When I try to install the patch with the command acs patch install, the ACS say me "Patch 5.1.0.55.6 is already installed". If I try to remove the patch, the ACS say me "patch 5.1.0.44.6 is not istalled". In the show version output command the version is 5.1.0.44
temis/admin# acs patch install 5-1-0-44-6.tar.gpg repository Repositorio_Backup
Patch '5-1-0-44-6' is already installed.
% Error: Failure to open / validate the patch
temis/admin# acs patch remove 5-1-0-44-6.tar.gpg
% Error: Patch 5-1-0-44-6.tar.gpg is not installed.
temis/admin# sh ver
Cisco Application Deployment Engine OS Release: 1.2
ADE-OS Build Version: 1.2.0.146
ADE-OS System Architecture: i386
Copyright (c) 2005-2009 by Cisco Systems, Inc.
All rights reserved.
Hostname: temis
Version information of installed applications
Cisco ACS VERSION INFORMATION
Version : 5.1.0.44
Internal Build ID : B.2347
Any ideas? tnx for help.
Tarik Admani
Please open a TAC case to have one of our engineers remove the patch and then install patch 6 again.
Tarik Admani
