Problem of ISE opning machin
After the problem that we were dealing with Cisco support on the server bug he asked to change the package parameters:" We changed the Setting on Server ( Package C-State limit change to C0/C1)" .
Then following this modification in the server we had another problem when we start the VM ISE and Cisco support he asked to open another ticket on Cisco ISE appliance.
the problem exactly is:
after that we reloaded to applied new setting ,so when start up  the ESXI host after that we checked ALL VM’s are bring up except ( Cisco ISE ) we faced issue failed (  power on )  many times  during 20 min after that we tried once it has succeeded  to power onCISCO ISE.png
Colby LeMaire
What are the error details?  It is possible that the VM was still updating as a result of the change.  Or something else was going on within ESXi.  Would need to see the error details to know more.
Damien Miller
Can you provide the full details of the Power on VM failed alarm. It's very possible that the ISE VM has the resource reservations it is supposed to have, but the other VM's being powered up first meant the host doesn't have the resources available to power the VM on.
hslai
I agree with Colby and Damien. You need to check and verify the errors in VMware ESXi. Each VM usually has logs (vmware.log?) with some info.
