problem replicating between ACS 3.2 and ACS ACS version 3.3
jengelbrecht
Is it possible to replicate between ACS 3.2 on the appliance 1111 and ACS version 3.3 on the appliance 1112
gfullage
No, replication can only be done to the exact same software version. The database changes with each version as new features are added, so replicating breaks across different versions.
The best way to do this is to upgrade your 1111 to 3.3 which will convert the database for you, then replicate to the 1112.
Thanks for the help. The problem is 1111 is the prodduction appliance. Can we downgrade the 1112 to 3.2?
