Problem with 802.1x on C2960S-48TS-L
zuev_oleg
Sometimes after rebooting device connected to 801.x port this device successfully perfoming 802.1x authentication
Oct 19 13:29:27.869 MSK: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/23, changed state to down
Oct 19 13:29:28.980 MSK: %AUTHMGR-5-START: Starting 'dot1x' for client (1060.4b76.0515) on Interface Gi3/0/23 AuditSessionID 00000000000023C057D460F9
Oct 19 13:29:30.831 MSK: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/23, changed state to up
Oct 19 13:29:30.836 MSK: %DOT1X-5-SUCCESS: Authentication successful for client (1060.4b76.0515) on Interface Gi3/0/23 AuditSessionID 00000000000023C057D460F9
Oct 19 13:29:30.889 MSK: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (1060.4b76.0515) on Interface Gi3/0/23 AuditSessionID 00000000000023C057D460F9
Oct 19 13:29:31.832 MSK: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/0/23, changed state to up
Gi3/0/23     1060.4b76.0515 dot1x   DATA    Auth      00000000000023C057D460F9
But port blocking any traffic to/from this device.
After wait a few minutes - starting new "Auth" session and this port is working normally
Oct 19 13:36:32.462 MSK: %AUTHMGR-5-START: Starting 'dot1x' for client (1060.4b76.0515) on Interface Gi3/0/23 AuditSessionID 00000000000023CB57DAD729
Oct 19 13:36:32.656 MSK: %DOT1X-5-SUCCESS: Authentication successful for client (1060.4b76.0515) on Interface Gi3/0/23 AuditSessionID 00000000000023CB57DAD729
Oct 19 13:36:33.270 MSK: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (1060.4b76.0515) on Interface Gi3/0/23 AuditSessionID 00000000000023CB57DAD729
If i shudown/no shutdown or reconnect ethernet wire - starting a new "Auth" sesssion and port working fine.
Port configuration:
interface GigabitEthernet3/0/23
 description ### Universal WorkPort ###
 switchport access vlan 42
 switchport mode access
 switchport nonegotiate
 switchport voice vlan 400
 switchport port-security maximum 3
 switchport port-security violation  restrict
 switchport port-security aging time 2
 switchport port-security aging type inactivity
 ip arp inspection limit rate 50
 authentication event fail action authorize vlan 997
 authentication event no-response action authorize vlan 997
 authentication host-mode multi-auth
 authentication port-control auto
 authentication periodic
 authentication timer inactivity 15
 mab
 mls qos trust device cisco-phone
 dot1x pae authenticator
 storm-control broadcast level 1.50
 storm-control action shutdown
 no vtp
 spanning-tree portfast
 spanning-tree bpduguard enable
 ip dhcp snooping limit rate 100
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.2(2)E9, RELEASE SOFTWARE (fc4)
On another switch models this configuration working without problems.
Any idea how to fix this?
Greg Gibbs
The first thing you should try is removing the 'switchport port-security' configuration from the switchport. It is not compatible with the mab/dot1x NAC features running on the same switchport and can cause race conditions and unpredictable behaviour.
The same is true of any Catalyst switch model.
Removing 'switchport port-security' configuration not helped.
PS. If remove port-security configuration - how to defend from 'mac flooding' type attack?
