problem with cisco ise 2.6, I do not have access to the interface policy sets and endpoints
Ali_Mrad
Hello , i have installed cisco ise 2.6 on vmware workstation , i don't have acces to configure policy sets ! that page loaded without any resnponse
i don't khnow wher is the problem, i have a free evaluation licence !
Should i buy a licence or what ?
Please i need help guys
2 Accepted Solutions
You could try a different browser, reload the primary admin node, and/or contact TAC if the issue persists. Some others have reported similar issues with the GUI so it might be something that is already addressed/known.
@nithinrs78901 I'm using Cisco SNS-3615 server and have ISE 2.6 patch 2.
Thanks to all, the problem is resolved by changing Mozila Firefox version (not working with Chrome and IE).
Best Regards
5 Replies 5
Damien Miller
All features work in the evaluation copy and I run ISE in VMware workstation myself. I can confirm it works, but you get some weird quirks if you don't have enough RAM or CPU. Do any of the GUI web pages load, or is it only the policy sets that are failing to come up?
I have the same issue, not able to access Policy Set page loading and loading without coming up.
I'm using SNS-3615
nithinrs78901
Plaese check the VM requirement of ISE 2.6.
Update the latest patch
Best Regards
