Problem with Data Access Permission for Endpoints
Jonathan Grim
Looking for help with a Data Access Permission issue.
The admin should only be able to add or delete an endpoint to a pre-defined endpoint identity group.
  • Good - When the admin logs into ISE, they only see the endpoints from the specified endpoint group.
  • Problem - When the admin creates a new endpoint and tries to assign the static identity group, there aren't any groups to pick from.
Screen Shot 2019-05-21 at 5.48.23 PM.pngScreen Shot 2019-05-21 at 5.48.06 PM.png
Hi @Jonathan Grim
Please check this thread Community Thread about Identity Management Access
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
