Problem with guest pc login and redirection
I'l try to be clear and direct
whan a pc is connected to the network for the first time and fails authentication (as it should) it is meant to be authorized on guest portal with web redirection and it does, everything works like a charm...
but there is a huge problema round the corner... if I disconnect the pc from the lan and then replug the connector it won't do anything it is supposed to do,
the only option is to wait for dhcp lease to run out and then everything turns fine until a new disconnection...
it looks like the switch doesn't catch the pc as being re-connected (maybe because it doesn't ask for a new ip and use the leased one), and no action is applied to the session, the dacl is marked as global (not peer) and webredirection doesn't happen anymore, changing port has the same result
the only difference from cisco document's switch config is that host mode is multi-domain
(and it seems that the session is not terminated by being triggered by the disconnection of the pc)
switch port violation policy is "mac-move"
any clue?
tahnk you all very much for your support
Tarik Admani
Can you post show run interface type x/y, show run | inc aaa. Also the model and version?
Tarik
Sent from Cisco Technical Support Android App
yes
aaa new-model
aaa authentication login default group radius local
aaa authentication dot1x default group radius
aaa authorization exec default group radius if-authenticated
aaa authorization network default group radius
aaa authorization auth-proxy default group radius
aaa accounting update periodic 5
aaa accounting auth-proxy default start-stop group radius
aaa accounting dot1x default start-stop group radius
aaa accounting system default start-stop group radius
aaa server radius dynamic-author
aaa session-id common
model
C2960S
12.2(55)SE2
thanks
Tarik Admani
Disregard.
