problem with ISE2.3 and AD 2016 WMI integration
m.markocevic
I want to integrate ISE 2.3 with Windows AD 2016 to enable passiveID in the network.
Configuration of DC is OK, but when I click on on the Test button I get error message.
Do you know what can be a problem?
BR Milan
afahmy
Try CN name instead of email address of administrator
If there are any firewalls between ISE and DC, please ensure ISE allowed to connect to DC on any ports. See also Prerequisites for Integrating Active Directory and Cisco ISE
You may also check Active Directory Requirements to Support Easy Connect and Passive Identity services
Additionally, turn DEBUG on passiveid and watch the debug log via CLI "show logging app passiveid-wmi.log tail". Attached is a sample log file.
PS: I tried it myself and ISE worked fine with Windows Server 2016 (Updated Feb 2018) Standard with Desktop Experience.
lekang
I'd like to know if those changes would be done differently in a multi Domain Controllers environment.
Thanks!
