Problem with portal guest Cisco ISE 3.1.0.518
Cghassan
We just installed Cisco ISE 3.1.0.518
Version 3.1.0.518
Installed patches 6 and 7
Product Identifier (PID) SNS-3615-K9
Version Identifier (VID) V0
ADE-OS Version 3.1.0.010
Access to the guest portal (wired and Wireless )is done with a username and password and we create them on ISE user group.
When an external guest client tries to access the guest portal. The portal asks the guest user to install the latest version of Java.
I installed Java but the problem persists.
Is it normal behavior? Do I need to have java? It is not feasible for all external users to have the JAVA version to access an invited portal.
This happens Windows 10 environments with the latest versions of Edeg, Mozilla and Chrome.
Can somebody help me?
thank you
ammahend
since you have already tried uncheck “require guest device compliance”.
see if this helps
https://community.cisco.com/t5/network-access-control/guest-device-compliance-settings-missing/td-p/3472459
seem to have worked on older version.
-hope this helps-
ammahend
see if this helps
-hope this helps-
Thanks a lot .
It works fine when i uncheck the Vlan dhcp release Page settings.
