Problem with RADIUS and VRF in Cisco 6500
BASARTAK1
I have the next config of radius authentication:
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius local
aaa session-id common
ip radius source-interface Vlan31 vrf LEGACY
radius-server host 10.10.4.18 auth-port 1645 acct-port 1646 key 7 XXXXXXXX
radius-server host 10.10.5.15 auth-port 1812 acct-port 1813 key 7 XXXXXXXX
radius-server vsa send accounting
radius-server vsa send authentication
The authentication don´t work
In the radius server the sniffer not detect the packets from the Cisco 6500 but the icmp packets from the 6500 arrive fine.
C6500# ping vrf LEGACY 10.10.4.18 SOUrce VLAN 31
Sending 5, 100-byte ICMP Echos to 10.10.4.18, timeout is 2 seconds:
Packet sent with a source address of 10.10.5.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
interface Vlan31
description XXXX
ip vrf forwarding LEGACY
ip address 10.10.5.254 255.255.254.0
no ip redirects
no ip proxy-arp
no ip mroute-cache
end
it's correct my configuration?
Can you help me?
What version of IOS are you running on your 6500?
Try the following configuration:
aaa new-model
aaa group server radius RADLegacy
aaa authentication login default group RADLegacy local
aaa authorization exec default group RADLegacy local
shoaibkhan
What VRF are you trying to enable this aaa ? If it not a per VRF AAA then simply define radius source as vlan31 - drop the vrf bit.
aaa new-model
The problem is solved
I had to include the following configuration
aaa new-model
aaa group server radius RADIUS-GESTION
aaa authentication login default group RADIUS-GESTION local
aaa authorization exec default group RADIUS-GESTION local
ip vrf forwarding GESTION
radius-server host 10.10.5.15 auth-port 1812 acct-port 1813 key 7 XXXXXXXXXXXXXXXX
radius-server host 10.10.4.18 auth-port 1645 acct-port 1646 key 7 XXXXXXXXXXXXXXXX
thanks for the help
