Problem with work group bridge authentication with ACS 5.x
Santosh Shetty
EAP-TLS authentication for workgoup brdige fails.
Folloing is the log on ACS
Authentication failed
12514 EAP-TLS failed  SSL/TLS handshake because of an unknown CA in the client certificates chain
12811 Extracted TLS Certificate message containing client certificate.
12814 Prepared TLS Alert message.
12817 TLS handshake failed.
12507 EAP-TLS authentication failed
12505 Prepared EAP-Request with another EAP-TLS challenge
11006 Returned RADIUS Access-Challenge
11001 Received RADIUS Access-Request
11018 RADIUS is re-using an existing session
12504 Extracted EAP-Response containing EAP-TLS challenge-response
11504 Prepared EAP-Failure
11003 Returned RADIUS Access-Reject
Tarik Admani
I have seen this issue before, the AP is present an old PAC and doesnt update until after you reboot. You can open a wireless TAC case and they will get you the right image as to when this was fixed. As a workaround you can extend the lifetime of the PAC in your authentication settings for EAP-FAST.
