Problems with connecting Printers via MAB
Maxim Bezzubov
I'm setting up a 2960S (WWS-C2960S-48FPS-L) with IOS image 152-2.E4 for ISE-based wired authentication. I have all the global commands and my RADIUS server (ISE 2.0) is reachable and RADIUS shared secret is verified at both ends. dot1x or mab auth on PC works fine, but stucked with problems with HP printer. Here is my config on port in closed mode. As I said - work fine with PC (MAB and dotx1) - with printer dont.
interface GigabitEthernet1/0/13
switchport access vlan 5
switchport mode access
ip device tracking maximum 3
authentication event fail action next-method
authentication event server dead action reinitialize vlan 5
authentication event server alive action reinitialize
authentication host-mode multi-auth
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
authentication timer restart 10
mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
dot1x pae authenticator
dot1x timeout tx-period 10
dot1x max-reauth-req 1
I've got
sh authentication sessions interface gigabitEthernet 1/0/13
No Auth Manager contexts match supplied criteria
and NO messages at debugging aaa, radius or on ISE Radius Livelog, just nothing.
BUT if i config port on the OPEN or LOW-INPACT mode by adding this
authentication open
ip access-group ACL-PREISE in
Extended IP access list ACL-PREISE
    10 deny ip any any
Voila - we have a session. Its working as it does.
sh auth session interface gigabitEthernet 1/0/13 details
            Interface:  GigabitEthernet1/0/13
          MAC Address:  x.x.x.x
         IPv6 Address:  Unknown
         IPv4 Address:  10.x.x.x.x
            User-Name:  <MAC>
               Status:  Authorized
               Domain:  DATA
       Oper host mode:  multi-auth
     Oper control dir:  both
      Session timeout:  N/A
      Restart timeout:  N/A
       Session Uptime:  1059s
    Common Session ID:  0A6401090000004C0905C7D2
      Acct Session ID:  0x00000060
               Handle:  0xD500002E
       Current Policy:  POLICY_Gi1/0/13
Local Policies:
        Service Template: DEFAULT_LINKSEC_POLICY_SHOULD_SECURE (priority 150)
Server Policies:
           Vlan Group:  Vlan: 5
              ACS ACL:  xACSACLx-IP-WIRED-INSIDE-56c57a49
Method status list:
       Method           State
       mab              Authc Success
Am I missing something obvious or hitting a bug? I thought I'd ask here before opening a TAC case.
MAB requires traffic from the endpoint to work. Typically devices without IP will request IP address which triggers MAB. For static IP devices, it may be a long wait till the printer sends a packet to the network. With that in mind, the result depends on how you are testing the printers. Interesting fact about many printers including HP printers is that they do not renew IP on interface link up/down. This is the case whether the printer is using DHCP or static IP. So when testing printers always power recycle the device or you will be waiting for a long time.
The 'authentication control-direction in' command will often expedite the process as it is possible for the printer to respond to broadcast and print requests. If you want to see 'authentication control-direction in' in action, simply send a directed broadcast (ping x.x.x.255, assuming router allows it) to the VLAN 5 subnet and you will notice that the MAB happens immediately for the printer.
Hosuk
6 Replies 6
thomas
Maxim, I highly recommend that you read our best practices for 802.1X switch configuration in the ISE Design Guide HowTo: Universal Switch Config.  It explains all of the individual commands, best practice settings and why you need authentication open.
This is our best practice Universal Switch Configuration for Low-Impact (change VLANs  per your deployment!):
description ACCESS (Multi-Auth w/ Low-Impact Mode)
switchport access vlan 10
switchport voice vlan 11
ip access-group ACL-DEFAULT in
authentication open
authentication event server dead action reinitialize vlan 10
authentication event server dead action authorize voice
mab
authentication violation restrict
authentication periodic
authentication timer reauthenticate server
authentication timer inactivity server dynamic
spanning-tree portfast
We do not recommend a default port ACL of only deny ip any any since this will explicitly prevent basic network services like DHCP & DNS which are required for most endpoints to be profiled or be URL-redirected to ISE for additional profiling, Guest Services or Device Registration.
Tnanks for your answer. You are talking about Low-Impact Mode. We are want to use a Closed mode.
As I said my switch port config works normal with Windows PC via MAB or dot1x. I know about default preauth ACL in Low-Impact mode, so I just demostrate that using ACL with deny ip any any  do a trick - printer is authorized via MAB. I have problem now just with printer.
I 've tried authentication control-direction in command in closed mode from the doc's that you show me - no luck...
Hosuk
Thanks for ypur answer.
I thinkning about it too. I will try to power off printer and on. I will let you know about result.
I have cheched this supposition and so I can tell you that you were right! Switching power off and on was resolved my problem. Printer is auth via MAB in closed mode. Many thanks.
Hi Thomas, how can I access the how to guide?
Thanks.
