Problems with installation of ISE 3.x on 2019 Hyper-V
james.king14
Having issue with installing ISE 3.x on 2019 Hyper-V server.  I get an error that the processor is not large enough.  Even though I have twice the size required.
james.king14
How can you tell which is which?  Thanks you have been very helpful.
10 Replies 10
What version of ISE?  3.0?  3.1? 3.2? Also the installer is reporting the speed of the processor is too slow.  What speed in ghz is your CPU in your host?
james.king14
The version is 3.1.x and the processor is at 3.2GHZ but it is a windows 2022 box.  I just found that out today.  we had a 2019 but the sysadmin upgraded.
https://www.cisco.com/c/en/us/td/docs/security/ise/3-1/compatibility_doc/b_ise_sdt_31.html
Lists Microsoft Hyper-V on Microsoft Windows Server 2012 R2 and later.  If your CPU/memory reservations are up to spec, I would say TAC would be your next step.
james.king14
I have the document on the specs for the Hyper-V installation.  I also have verified that Hyper-V will work on most Windows systems.  I am trying to open a TAC case, but I cannot get into the ISE CLI, since it will not load.
Is this a Gen2 Hyper-V VM?  There is a known issue on 3.1 with Gen2 VMs.  Cisco TAC has a hot patch or you can redeploy on a Gen1 VM.
Hi everyone, having the same issue. Deploying ISE 3.3 from scratch using ISO / Hyper-V VM. Generation 1 VM's and getting similar error. Our host has enough Memory 512 GB, CPU 2.0 GHZ, disk (over 5 TB) for those Hyper-V VM's.
Hi ajc. I know this was from some time ago but did you ever find a solution? I am seeing the exact same issue as in your screenshot trying to build 3.3 on Hyper-V. Thanks
UPDATE: I managed to get around this issue by enabling CPU compatibility mode, however don't have the issue on another Hyper-V node, same hardware, so still interested if you found another solution.
Hi Davies, I forgot to post my solution. For bigger Hyper-V VM's, I used Generation 2 and problem solved. I read somewhere that they are also recommending install from PATCH 1 on ISE 3.3 or 3.2 instead of going directly to the latest patch on that version due to some identified issue I do not recall. So basically I am installing to be safe patch 1 and patch 2 on version 3.3.
Also I did not install any hot patch because I do not like it and I had really bad experience with that kind of approach back in the days when running ISE 2.2
I also got this to work for 3.3 ISE-PIC by enabling compatibility mode.
https://learn.microsoft.com/en-us/windows-server/virtualization/hyper-v/manage/dynamic-processor-compatibility-mode?tabs=hyper-v-manager
I was running into CSCwm59777 with our internal domain, so had to install 3.3 instead. Xeon gold 2.2 Ghz HyperV host reporting under 1 Ghz in the installer for 3.3.
VM settings:
Gen 2
32 GB RAM
16 vCPU
60 GB HDD
1 NIC, set appropriate VLAN ID.
Disabled secure boot
also disabled snapshots
james.king14
