Problems with tacacs Authorisation with ACS5.3 and Catalyst 3750s
                I am in the process of upgrading the ACS from 4.1.1. to 5.3,
I have Catalyst 3750s with various levels of IOS and with ACS 4.1.1 there were no problems
AAA config on switches as below
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login console local
aaa authorization exec default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
now with ACS5.3  I find that switches running 122-35.SE5 (ipbase) no problems, all ok
but switches running later IOS 122-50.SE5, 122-55.SE5, and 15,0.1 I    users with the privilege level of 15 fails authorization most of the time.
users with privilege  level 7 no problems
on advise from various  entries on the support forums as below but did not make any difference
can anybody help with this?
aaa new-model
aaa authentication enable default group tacacs+
aaa authentication dot1x default group radius
aaa authorization config-commands
aaa authorization commands 1 default if-authenticated
aaa authorization commands 15 default group tacacs+ local
6 Replies 6
these many commands are not required. Esp dot1x authentication commands.
what is the configuration you have done on the ACS 5.3? that is the place we have to see.
Please check the logs when the Users are getting failed.
Nitesh
Tarik Admani
Nitesh is correct,
In ACS 5.3 the default command set is set to deny all. However this may not appear until you select the customize button in your authorization profile to make the "Command Set" option visible, there you will be able to set the condition to use the command set you want.
Tarik Admani
Tarik,
I think the problem is with the Cat 3750 as I can login into a switch running 122-35.SE5 ok, but when I log into a switch running 122-50.Se5 I get 'Authorization failed' message, this is for a user with a privilege level of 15. But no prblems with user with a privilege level of 7,
There must be a difference in the way Tacacs is handled betwen the different levels of OS in the Switch
What is currently your show run | inc aaa?
Tarik Admani
*Please rate helpful posts*
We opened a case with Cisco TAC, and after much looking around came to the conclusion the problem was:
the "tacacs-server host xx.xx.xx.xx  single-connection" command on the Cat 3750's
removed the "single-connection" from the command  and now  authorization ok no longer intermittent
We have had these switches some time and the "single-connection " is no longer required.
Thanks for he response.
