Radius problem after first server failed
Guillaume Roche
Level 2
Level 2
i have a 3560 configured with two radius servers .
I had a problem so the 3560 switches to the secondary server . Now the first server is now available and working but the switch still sees like "DEAD" .
How to force the switch to "re-up" the first server ?
Best regards,
Guillaume
Tarik Admani
If you have the radius-server deadtime configured then the switch will wait till that timer expires. If you want to manually force it active you should be able to run the test aaa command and specify the server option and see if that works. First confirm if that option is set and verify the value. Thanks,
abwahid
Level 9
Level 9
Hi Guillaume,
I think you have configured a deadtime for radius server group, it will respnose after the deadtime expire.
if you want to up it before the time, you have to use no deadtime command to set the Radius Server group to default 0 minutes delay
so Radius server keep responding to all authentication requests.
nspasov
You can also setup a "test" aaa radius username/password that will periodically test the configured aaa servers. A previously "dead" server would be marked as "alive" when the test account tries a login. I can even help you with the syntax if you tell me the version of code that you are running.
Thank you for rating helpful posts!
