Radius session not found ISE and Guest Portal / Sponsored Portal
vaniat
When client joins network for a first time, we get "Radius session not found. Please contact helpdesk for assistance". After turning WiFi of the device Off and back on, everything works fine. We are running 17.11.1 on WLC9800 and 3.2 patch 4 on ISE
47 Replies 47
Arne Bier
I had this phenomenon many years ago with ISE 2.2/2.3 but there were F5 load balancers involved. Sadly I can't recall what the resolution was. Perhaps you already have, but my checklist would check the following
Check that 9800 Integration Guide that Adam posted and compare your IOS-XE configuration and ISE configuration as close as possible. Adam makes a good point about the CoA - check that on the 9800 the IP address of ISE is listed as a client and if need be, re-enter the RADIUS pre-shared key exactly as it appears in ISE for that 9800 (rule that out just to preserve your own sanity!)
show run | sec radius
show run | in aaa
show run | in http
show run | sec access-list
Enable a tcpdump on the ISE interface and then delete MAC from WLC/ISE and try to catch the issue - analyse in Wireshark for clues
Analyse your RADIUS Policy Set to mimic how the Wireless MAB traffic must flow - post it in the Community if you want and we can also have a look.
By the sounds of it, you have done everything right.
Last resort things:
  • Restart the 9800
  • Restart ISE (in my experience, restarting ISE doesn't fix authentication issues ... it's usually something else ...)
Hi friend
Sorry for late reply
There are two authc and authz
1- open and mac filter (before portal)
2- open and mac filter (after portal)
These two stages happened because of CoA
So please
In wlc do (before and after)
Show client detail
In ISE
In live log
Share here
MHM
Attached is radioactive trace of client that first fails and then wifi is turned off and back on and then it all works fine. On WLC cli I am not able to find "show client detail"
I will try today to make wireshark capture and analyse it.
thanks a lot
waiting the wireshark files
MHM
In 9800 WLCs you go to Monitoring > Wireless > Clients and then you click on the client which will open a new tab with all the details.
I think this issue could potentially be caused by having a split session between the PSNs. If you have multiple PSNs, did you create multiple authorization rules for guest traffic redirection?
vaniat
Client State Servers
None
Client ACLs
None
Client Entry Create Time
222 seconds
Policy Type
WPA2
Encryption Cipher
CCMP (AES)
Authentication Key Management
FT-PSK
EAP Type
Not Applicable
Session Timeout
86400
Authen Status
Success
Session Manager
Point of Attachment
capwap_9000038c
IIF ID
0x9000038C
Authorized
TRUE
Common Session ID
0A030A0A000095E65F0C5FE2
Acct Session ID
0x000063bf
Auth Method Status List
Method
MAB
SM State
TERMINATE
Local Policies
Service Template
wlan_svc_ALMIRQAB_local (priority 254)
VLAN
GUEST
Absolute Timer
86400
Resultant Policies
Preauth URL Filter
URL_FILTER
Preauth URL Filter
GUEST_URL
URL Redirect ACL
REDIRECT
VLAN Name
GUEST
VLAN
102
Absolute Timer
86400
DNS Snooped IPv4 Addresses
None
DNS Snooped IPv6 Addresses
None
This before portal
And it totally correct for redirect acl and url.
MHM
vaniat
and this is after, when it works correctly:
None
Client ACLs
None
402 seconds
Policy Type
WPA2
Encryption Cipher
CCMP (AES)
FT-PSK
EAP Type
Not Applicable
Session Timeout
5714853
Authen Status
Success
Session Manager
Point of Attachment
capwap_9000038c
IIF ID
0x9000038C
Authorized
TRUE
Common Session ID
Acct Session ID
0x000063bf
Method
MAB
SM State
TERMINATE
Local Policies
Service Template
Server Policies
Absolute Timer
5714853
VLAN
99
Resultant Policies
VLAN Name
CONTROL
VLAN
99
Absolute Timer
5714853
None
None
This wrong' the user authz using PSK not MAB even if it pass portal auth.
And vlan 102 and then 99!!!!
It not same wlan I think.
Can I see l2 and l3 secuirty for this wlan again
MHM
vaniat
Indeed, after log in, client gets to its specific VLAN. 102 is portal VLAN and 99 is designated VLAN for that specific user (see below).
What do you mean by "user authz using POSK not MAB"?
Result
User-Namefdoyle1
ClassCACS:0A030A0A000095E65F0C5FE2:my681-ise001/495381330/456274
Session-Timeout5714853 seconds
Termination-ActionDefault
Tunnel-Type(tag=1) VLAN
Tunnel-Medium-Type(tag=1) 802
Tunnel-Private-Group-ID(tag=1) 99
We need to focus to issue and solve it one by one
Guest must not use PSK (it guest how it have key) so it use l2 secuirty none and mac filtering select' so can you confirm you use this l2 secuirty or not?
MHM
vaniat
Client requested to have extra security layer (PSK) so not everyone can try to connect to that SSID. Next to that, client gets account and is redirected to portal. And this works fine, just not the first time.
Wireshark capture. Calling station is a2-35-82-d1-87-be. It can be found with 10.10.102.161 IP address.
I will check Guest WPA + portal in CWA if it support or not
MHM
Please.. It kind of works (only second time) and I was told of deployments that work fine and use PSK. Also in my understanding, PSK is more on authentication/encryption side while MAB is authorisation side, hence PSK is starting point, but one you get to hte portal you already have IP level of communication in place. (please correct me if I am wrong)
