Radius session overlap between simultaneous Wireless dot1x and AnyConnect connections
Matt Craig
Frequent Visitor
Frequent Visitor
ISE 2.7
If a user connects their device to a Wireless dot1x SSID AND AnyConnect at the same time, ISE does not show separate sessions as Radius reports the same username and mac address for both.
The most recent to connect simply re-uses the existing session from the first: "RADIUS is re-using an existing session"
This is not a big deal to me, but it is confusing our technicians... looking for a Wireless client and not finding it because session is from AnyConnect or vis versa.  Many unwanted support cycles.
Is there a way to differentiate here?
0 Replies 0
