Replication problems v3.3
lni1
Level 4
Level 4
When replicating from primary to backup, a certain number of temporary accounts are created (seen as numbers in the logs). After replication these numbers remain as logged-in users. What is happening during replication ??
Many thanks,
drolemc
Level 11
Level 11
Changes to user-defined fields in user records do not appear to replicate. After the user-defined fields are changed in the Interface Configuration section on the primary Cisco Secure ACS server and replication succeeds, the secondary Cisco Secure ACS server does not display the changes to the user-defined fields in the HTML interface.
Workaround/Solution: The changes to the user-defined fields do replicate successfully; however, to see the changes on the secondary Cisco Secure ACS server, restart the CSAdmin service.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/prod_release_note09186a008018492b.html
