Showing results forĀ
Search instead forĀ
Did you mean:Ā
Running an inventory for ACS 1113 appliance
venom43212
Level 4
Level 4
I want to gather an inventory of all devices  that shows the AAA client name, IP addresses, authentication method and key under my Network Configuration on my ACS appliance. Is there a report to run in it that will shows this, or is something that has to be done manually? Thanks in advance.
andamani
I don't think you can take a key of the device. But you can certainly download the Device name, ip address, Type and NDG if any.
Please do the following:
network configuration > search.
keep the parameters as
1. name *
2. Ip address *.*.*.*
3. type any
Click on search.
You will get the list of all clients and a download option.
Just click on the download option and get the file.
Hope this helps.
Anisha
P.S.: please mark this thread as answered if you feel your query is resolved. Do rate helpful posts.
