Running RADIUS and TACACS on the same ACS
xhackuss1
I have an ACS server 3.2 currently running on my network with all my aaa clients configured for TACACS+. I have the need to get some WLAN users authenticated through the ACS using RADIUS.Can I run both RADIUS and TACACS+ on thesame ACS server?
Collin Clark
Yes you can.
Jagdeep Gambhir
Level 10
Level 10
Yes, you can set up same device as both Radius and tacacs.
Example , ACS-->Network configuration-->ADd
Host1--->x.x.x.x--->Authenticate using Tacacs
Host2--->x.x.x.x--->Authenticate using Radius
Only host name has to be different.
~JG
Do rate helpful posts
