Security access control per device level
wmmak
Level 4
Level 4
Dear all,
802.1x can only apply access control on user level, i.e. that user can use any pc/notebooks to gain access to network.
How about per device level? using MAC address control can be a choice, but it is not scalable as it increases admin overhead.
Is it any better method/solution out there?
Thanks a lot in advance.
mak
mike.iacovacci
Community Member
I looked into the same thing, and found that using EAP-TLS along with Machine Certficates is a good solution, this way the "device" must have a certificate to pass the dot1x auth. The only drawback is the request,grant, and install of the certs can be daunting for a large org. Although, GPO can help if you are in a Windows AD Environment.
