shell authorization works only on vty lines and not on console
o-ziltener
Why does command authorization only works for the vty line and NOT for the consoles?
I use ACS for Win 3.3.(1)
any input are very welcome
Configuration
aaa new-model
aaa authentication login VTY group tacacs+ local
aaa authentication login CONSOLE group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
line con 0
login authentication CONSOLE
line vty 0 4
login authentication VTY
gfullage
By default, console authorization is turned off, even with all the standard authorization commands in your configuration. This was done deliberately to leave the console connection as a "back door" to get into the router in case you lock yourself out (which is easy to do with authorization). The theory is that if someone has access to your console port, you have a lot more to worry about than command authorization :-)
If you really, really want to do this, make sure it works fine first on the VTY's, and then issue the hidden command:
aaa authorization console
